Customise Lead Capture Email
Discussion in 'Lead Capture WordPress Plugin' started by ezmarketing, May 9, 2016.
  1. ezmarketing
    ezmarketing New Member
    Hi, I want to customise the email that the store owner will receive when someone contact them via lead capture form. At the moment I am getting Wordpress as a sender name and [email protected] as a senders email. I would like to have an actual person's (who filled the form) name as senders name and their email as a sender's email set up. Can you help me please? Where can this be edited?
    Thank you
    Code is as follow..
     /* auto-detect the server so you only have to enter the front/from half of the email address, including the @ sign */
    function xyz_filter_wp_mail_from($email){
    /* start of code lifted from wordpress core, at http://svn.automattic.com/wordpress/tags/3.4/wp-includes/pluggable.php */
    $sitename = strtolower( $_SERVER['SERVER_NAME'] );
    if ( substr( $sitename, 0, 4 ) == 'www.' ) {
      $sitename = substr( $sitename, 4 );
    /* end of code lifted from wordpress core */
    $myfront = "info@";
    $myback = $sitename;
    $myfrom = $myfront . $myback;
    return $myfrom;
    add_filter("wp_mail_from", "xyz_filter_wp_mail_from");
  3. ezmarketing
    Hi Priyanka,
    I followed the instructions and added the code and changed info@ , which updated the email address upon lead form receipt, but the sender name is still coming as WordPress- see the file attached. I would like it to say the site name instead, what can I edit to achieve it? Thanks
    Would you please send us your dashboard details at [email protected] along with this thread link so that I can figure out the issue and able to resolve that...?
  5. thecoldapple
    thecoldapple New Member
    I tried to follow this and got confused at Step 3. I just sent an email. All my e-mails from this form is going to SPAM WordPress and arriving like this wordpress@ via gator3139.hostgator.com
  6. Naveen
    That's actually because of your server email settings. You can contact your host provider in this regard.
  7. thecoldapple
    How can I get the email to come from a regular email address and not [email protected]> via gator3139.hostgator.com
    We can't reply. It replies to wordpress@
  8. thecoldapple
    I just got off the phone with Hostgator, after an hour, and they say it's the plugin.
    The issue is that when someone fills out the form, it is being sent to me in this way-> wordpress@a> via gator3139.hostgator.com
    Why can't it be like Contact 7 Form. You can pick the e-mail and it's fine. All of my customers leads are going to spam and on Yahoo they don't get sent at all.
    I need help, I was on the phone with the hosting company for an hour and they could not solve it.
  9. Naveen
    For your information, the theme uses default mailing feature provided via WordPress and that's why you are getting the emails like this.
    You can try using some other email say try to use your Gmail id there. I hope that will work.
    Contact form 7 has it's own customized email template so it works differently.
    Warm Regards!
    Naveen Kolhe
