Hi Guys, on the front page of roadfighter there is a section for posts and testimonials. How can I get rid of this? Ideally I would like to put a social gallery feed in that section ie. juicer.io feed) http://www.uppermurraytourism.com thank you so much,
Hello, Greeting from InkThemes, To make the desired changes, just paste the code in the Additional CSS section of the theme. Go to (Dashboard->Appearance->Customize->Additional CSS). Code: ul.featurebox { display: none; } .feature_testimonial { display: none; } Kindly refer the video I am attaching below that will help you. To put a social gallery feed in that section you can use a plugin and put the shortcode of the plugin in the widget area. I hope the above information will help you. Regards, Akbar InkThemes.com
Thank you Akbar - worked a treat - the only issue is that the widget panel is narrow....can I get access to the full width of that area?
Hello, Greeting from InkThemes, Yes, this can be possible by making some changes in the coding. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will do the needful. Regards, Akbar InkThemes.com
