Customize Settings No Longer Available
Discussion in 'ColorWay WordPress Theme' started by mcmarketing2017, Mar 22, 2021.
  1. mcmarketing2017
    mcmarketing2017 New Member
    It seems that the GA code added with the Customizer is displaying incorrectly and causing a php error that may be blocking the Customizer from displaying all options, only Widgets is showing.
    http://www.eventproductionservices.group/
    The tag has been changed from this;
    gtag('js', new Date()); gtag('config', '#######')
    to this;
    gtag('js', new Date()); gtag('config', '#########');
    This is causing this error;
    Uncaught SyntaxError: expected expression, got '&'
    I have added the correct GA code with the theme editor but I can not remove the bad code the Customizer has added. Code I added is at line 9 of the html of the homepage. The bad code is at line 95 96 in Firefox source display of the page.
    I do not have access to the database unless I add a plugin for that.
  2. mcmarketing2017
    I have found another error on the Customizer settings in the admin, says the error is in wp-includes/js/jquery/ui/slider.min.js?ver=1.12.1 error at line:9:661
    Uncaught TypeError: this._addClass is not a function
        jQuery 8
        _initControls http://www.eventproductionservices.group/wp-admin/js/iris.min.js?ver=1.0.7:5
        e.widget/</h[t]</< jQuery
        _create http://www.eventproductionservices.group/wp-admin/js/iris.min.js?ver=1.0.7:5
        jQuery 7
        _create http://www.eventproductionservices.group/wp-admin/js/color-picker.min.js?ver=5802dafb0b915a15b351118d54f79765:2
        jQuery 7
        ready http://www.eventproductionservices.group/wp-admin/load-scripts.php?c=0&load[chunk_0]=wp-hooks,heartbeat,customize-base,customize-controls,customize-widgets,mce-view,imgareaselect&ver=5.6.2:8
        initialize http://www.eventproductionservices.group/wp-admin/load-scripts.php?c=0&load[chunk_0]=wp-hooks,heartbeat,customize-base,customize-controls,customize-widgets,mce-view,imgareaselect&ver=5.6.2:8
        jQuery 2
        Class http://www.eventproductionservices.group/wp-admin/load-scripts.php?c=0&load[chunk_0]=wp-hooks,heartbeat,customize-base,customize-controls,customize-widgets,mce-view,imgareaselect&ver=5.6.2:6
        i http://www.eventproductionservices.group/wp-admin/load-scripts.php?c=0&load[chunk_0]=wp-hooks,heartbeat,customize-base,customize-controls,customize-widgets,mce-view,imgareaselect&ver=5.6.2:6
        <anonymous> http://www.eventproductionservices.group/wp-admin/load-scripts.php?c=0&load[chunk_0]=wp-hooks,heartbeat,customize-base,customize-controls,customize-widgets,mce-view,imgareaselect&ver=5.6.2:8
        each jQuery
        jQuery 13
    slider.min.js:9:661
  3. mcmarketing2017
    I found the issue with Customizer not displaying the settings, it was the "AppointUp" plugin version 1.0.5. It had also blocked UpDarft from fully loading, had to disable it to be able to use UpDraft. I disabled it and the settings in Customize were available again. Will there be an update to the AppointUp plugin to fix this?
  4. shemaela21
    shemaela21 Guest Staff Member
    Warm Wishes From InkThemes,
    We have shared the theme's zip file with you via this emails address of yours [email protected]
    Kindly download it and install it on your website.
    I hope it will help you and let us know if there is anything else with which we can help you.
    We will be happy to help you.
    Shemaela
