Customize Theme Font Help Please!!
Discussion in 'Appointway WordPress Theme' started by conceptsnet, Jul 30, 2015.
  1. conceptsnet
    conceptsnet New Member
    How do I change the Font of the Appointway theme.
    Please help?
  2. Sobhagya
    Sobhagya Guest
    You can resolve it yourself, All you have to do is just go to Dashboard->Appearance->Theme Options->Styling Option->Custom CSS
    field and try to cut paste the given below CSS code there.
    body {
        font-family: Domine, 'Lucida Sans Unicode', 'Lucida Grande', HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, sans-serif;
        p {
        /* font-family: Domine, 'Lucida Sans Unicode', 'Lucida Grande', HelveticaNeue, 'Helvetica Neue', Helvetica, Arial, sans-serif;
        h1, h2, h3, h4, h5, h6 {
        /* font-family: 'Domine', sans-serif; */
        font-weight: normal;
        color: #010101;
    Note: change font family by your desired font
    I would be glad to assist you further,
  3. conceptsnet
    Thank you..Can you also tell me how to change the font size..
  4. Sobhagya
    Sobhagya Guest
    Could you please provide your site URL along with some edited screenshots of which section you want to change font size, so that I can assist you accordingly. If you are unable to create screenshots then you can use www.screenpresso.com
    that will help you to create screenshots.
    Do let me know.
  5. conceptsnet
    I have attached screenshot. I want to change the fonts to copperplate and hurtmold as well as the font sizes to bigger size
    Please help
  6. Sobhagya
    Sobhagya Guest
