Customized styling
Discussion in 'Black Horse WordPress Theme' started by lina2015, Aug 5, 2015.
  1. lina2015
    lina2015 New Member
    I'm just exploring the theme. How to adjust for a customized colour scheme other than the defaults?
    Many thanks in advance
    K
  2. Sobhagya
    Sobhagya Guest
    Kindly follow the step which mentioned in the below video link.
    http://screenpresso.com/=U9qrb
    I would be glad to assist you further,
  3. lina2015
    lina2015 New Member
    Hi and thanks for your answer! Sorry for not beeing clear of what I meant - besides the color schemes that there are now, how can I change e.g. the blue to purple?
    - K
  4. Sobhagya
    Sobhagya Guest
    You can resolve it yourself, All you have to do is just go to Dashboard->Appearance->Theme Options->Styling Option->Custom CSS
    field and try to cut paste the given below CSS code there.
    .header-container {
        background: #800080 !important;
    .feature-icon .highlight {
        color: #800080 !important;
    #filters li:hover, #filters li.active {
    #filters li {
        border: 1px solid #800080 !important;
    .main-footer {
    .footer .footer-line {
        background: #710071;
    .flex-caption-wrapper {
        background: rgba(128, 0, 128, 0.53) !important;
    .footer .contactform input[type=submit] {
        background: #560056 !important;
    .footer #searchform {
        background-color: #560056 !important;
    .bottom-footer-container {
    .footer .contactform textarea {
        background-color: #DA9CDA !important;
    #menu li a {
    .footer .contactform input[type=text], .footer .contactform input[type=email] {
    .downarrowclass {
        border-top-color: #DA9CDA !important;
  5. corywebs
    corywebs New Member
    Hi i am having trouble changing my theme colour to anything but the defaults none of the css code i put in works
  6. nitin
    nitin Guest
    Instead of the option to put CSS code to change the theme color, you can easily do it from the 'Styling Options' panel in 'Theme Options'. please follow the screenshot given below.
    Nitin
