Customizing problems and more
Discussion in 'Blackriders WordPress Theme' started by feaministries, Aug 21, 2013.
  1. feaministries
    feaministries New Member
    I have tried to edit the lead capture, change the color of theme and change the click to call button info. Nothing is working, I just purchased the theme today 8/21/13 and it doesn't seem to work at all. Could somebody help me, or give a support link of a fix for this?
    Thank You,
    J. Powell
  2. supp aoa
    supp aoa New Member
    Hello J.Powell
    To change the colour of the theme from within the wordpress dashboard select Appearance > Styling options you will see the colour options on the top menu above custom CSS.
    To edit Click to call button select Appearance > General Settings then scroll down until you find the Top Right Contact Details Section. Enter the text you want here.
    You haven't said exactly said what you want change about the lead capture form but you can add and remove items in the custom leads form menu also under Appearances.
    I hope this is the information you are looking for.
    Many Thanks,
    Alan
  3. webtulio
    webtulio New Member
    I'm having the same problem.
    When I change the color of and click on save all changes, back to the area of issues and nothing happens.
    Bought on 21/08.
  4. feaministries
    Thank you for your rely Alan. I followed your instructions and I save the changes and still nothing happens. I have changed the click to call info several times. Should I uninstall the theme and try to re installedit? Also, I had installed the free one and bought the premium version. Should I uninstall both the free and premium? Typically you can switch from theme to theme, but wanting to make sure I am doing everything I should be doing.
    Thank You,
    J. Powell
  5. Gourav
