Question #1 - After following the thread about "removing the fourth featured box" on homepage, the third box is now underneath the first two. What do I need to alter in the custom style sheet to make all three boxes in one roll? Question #2 - How do I remove the circle effect in the featured boxes on homepage? I want them to be square. Thank you!
1.For your first issue You have done something wrong while removing the fourth featured box, Undo complete process and again remove it carefully. 2.For your second issue Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: .feature_inner_box .circle img{ border-top-left-radius: 0px; border-top-right-radius: 0px; border-bottom-right-radius: 0px; border-bottom-left-radius: 0px; } .feature_inner_box .circle{ border-top-left-radius: 0px; border-top-right-radius: 0px; border-bottom-right-radius: 0px; border-bottom-left-radius: 0px; } This will solve your issue.
Thank you! That did the trick. I did not delete the extra </div> tag, that is why it was not laying out correctly. I have one more question: I need for those images to be 290px x 100px -- where and what do I add to the style? Thank you very much for your help.
The total width of theme layout is 960px, So it is not possible to add that much long width images in that area,If you do that than it will break the layout of the theme.
