customizing slider & testimonial boxes
Discussion in 'RoadFighter WordPress Theme' started by syed, Sep 14, 2014.
  1. syed
    syed New Member
      File size:
      141.8 KB
      2
  2. Pramod
    Pramod Guest
    Unfortunately there is not a way to change the slider with us.For this you have to hire freelancer.
    For second issue please use space in your description section of feature column.
    Pramod
      File size:
      74.5 KB
      1
  3. syed
    syed New Member
    can i change the slider movement action?
    i think at present the slider movement action is "fade"
  4. Pramod
    Pramod Guest
    You can only change the speed of slider, Its action cannot be changed.
    Pramod
      File size:
      82.1 KB
      2
