Dancing Squares do not dissapear
Discussion in 'ReThink WordPress Theme' started by mattes, Jan 14, 2015.
  1. mattes
    mattes New Member
    to be honest, I really like the effect, but it seems that something is not working properly on my site.
    After activating (or previewing) the new theme the "dancing squares" are all I see. No start page is loading.
    Best Regards
    Matthias
  2. Pramod
    Pramod Guest
    Hello Matthias!
    May be any large image are used which may take too much time to load the website.
    Pramod
  3. mattes
    mattes New Member
    Hi Pramod,
    I only use one small image on the first page. Could it be caused by other plugins or themes?
    Regards
    Matthias
  4. Pramod
    Pramod Guest
    Hello Matthias!
    May be caused by any plugin.Some time some plugins use libraries or jquery or images from other places and they take times to load.
    Please make your cache and cookies clear and check theme without any plugin.
    If it works then activate one by one required plugins.
    Pramod
