Decrease Vertical Space throughout Home Page
Discussion in 'Andrina WordPress Theme' started by marmoset, Aug 6, 2013.
  1. marmoset
    marmoset Member
    The theme is great but there is generally too much vertical space between elements.
    I would like to decrease the white space between header, slider, and featured pages, as per attached screenshot.
    Please let me know how to do this.
    Paste this code in Custom CSS
    .menu_wrapper{
    margin-bottom:5px;
    .slider-wrapper{
    height:480px;
    .feature-content {
    margin: 0 20px 10px 0px;
    Adjust its value as per your requirements.
  3. marmoset
    marmoset Member
    Great Gourav thanks
    How do we reduce the depth of the shadow coming from the slider?
  4. Piyush
    .slider-wrapper {
    background-position-y: 400px;
    You can adjust this value as per your requirements.
  5. marmoset
    marmoset Member
    Hi Piyush
    I entered this code and altered the value many times and it made no difference to the depth of the shadow coming from the slider- please advise
  6. Piyush
  7. marmoset
    marmoset Member
  8. Gourav
    .slider-wrapper {
    background-position-y:392px!important;
  9. marmoset
    marmoset Member
    Hi there
    This did not work either- i reduced the setting to 100px but no difference
  10. Piyush
    .slider-wrapper {
    background-position-y: 400px!important;
    height: 450px;
    Do not change the value "background-position-y" , but you can adjust the value "height" as per your requirement.
  11. marmoset
    marmoset Member
    Hi
    This does not work
    A reminder of my second question - what I want to change is 'The Depth of The Shadow coming from the slider - not the distance between the slider and heading.
    How do we do this?
  12. Piyush
    The shadow of slider is shown there with the help of "slide-shaddow.png" image.
    There is an another way to do that.
    Go to images directory present in your theme directory and replace your image with present "slide-shaddow.png" image or edit it and reduce its shadow depth
    with the help of photoshop tool or any other photo editor tool .
    The name of image is "slide-shaddow.png" image.
    Note:- Use same name for your edited image and remove the previous image.
    See the link for the reference.
    http://www.inkthemes.com/how-to-edit-internal-files-through-ftp/07/
