I am currently using the teal-green under the Theme Stylesheet but would like to change to a custom color... is there a way to update change this?
Hello Kaocoaching, Thank you for contacting us, Could you please send us some edited screenshots of your issues so that we can have a detailed look over your issues and will try to resolve them as soon as possible. Thanks & Regards! Swapnil Gupta, InkThemes.com
Hi! I'd like to be able to edit the color of all the teal colors in the screenshots... Line above menu Thick block/line below menu and logo Block of heading text for blog posts both from the featured image (home page and blog page) and on individual posts Slider text block Footer widget area along with bars above and below
All the colors CSS is placed in the theme directory inside butterbellytheme/css/color Choose the color css which you want to customize. All the sections and colors are mentioned in the hex color code. You just have to make the changes to the hex colors and everything will be changed accordingly. One thing to note. Make sure that the same color css file on which you are making your custom changes is also selected on the themes options panel as well.
