Default Colour Styles
Discussion in 'Slice WordPress Theme' started by dinobravo10, Sep 2, 2014.
  1. dinobravo10
    dinobravo10 Member
    HI Team,
    1. Please assist if i want to change the theme stylesheet to a custom one which unfortunately doesnt appear in the drop down under the styling options.
    2.Also what to change the colour of bottom area where the footer widgets are located as it remains grey whenever i change to a different stylesheet.
    3.Want to also change the background colour of the area between the Home Page feature sections.
    Thanks.
  2. Pramod
    Pramod Guest
    Please provide URL of website.
    Pramod
  3. dinobravo10
    dinobravo10 Member
  4. Pramod
    Pramod Guest
    Please explain little bit more about all the three issues. About colors you want to keep with your website.
    Pramod
  5. dinobravo10
    dinobravo10 Member
    Please see images snipped from www.mkleetech.com
    1.Right now the i've selected the blue theme stylesheet,I want a white colour in place of the blue coulor. Image Area 1
    2. Want to also change the background colour of the area between the Home Page feature sections. Image Area2
    3.The footer area is greyish black,i want to change it to another coulor aswell. Image Area 3
    Thanks and Kind Regards.
  6. Pramod
    Pramod Guest
    .header-container {
    background: forestgreen;
    .page-container
    background: yellow;
    .content-bottom
    background: green;
    .footer-container .footer{
    background: red;
    Please change color by name or by code(eg. #123456; #122222; red,green,white etc.)as per your need
    Pramod
  7. dinobravo10
    dinobravo10 Member
    Thanks it worked on most parts but the menu bar and some footer section remains same colour how do i change that? Please see pictures
  8. Pramod
    Pramod Guest
    Use below code and paste in custom CSS.
    For menu:
    menu-container
    background:red;
    #menu li a:hover
    background:green !important;
    #menu li.current_page_item a
    background:yellow !important;
    For footer:
    .footer-container
    background:pink !important;
    .bottom-footer-container
    background:red !important;
    Pramod
