Delay In Items Showing Up
Discussion in 'ColorWay WordPress Theme' started by 1stopnonprofitshop, Nov 14, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    I want all the items on the website to show up at once...not as you scroll down. How do I change this?
    theme1.1stopnonprofitshop.com
  2. nitin
    nitin Guest
    To turn off the animation, just paste the code given below in Custom CSS section
    .animation_started.animated {
     /*CSS transitions*/
     -o-transition-property: none !important;
     -moz-transition-property: none !important;
     -ms-transition-property: none !important;
     -webkit-transition-property: none !important;
     /*CSS transforms*/
     -o-transform: none !important;
     -moz-transform: none !important;
     -ms-transform: none !important;
     -webkit-transform: none !important;
     /*CSS animations*/
     -webkit-animation: none !important;
     -moz-animation: none !important;
     -o-animation: none !important;
     -ms-animation: none !important;
    Hope this helps...!
    Nitin
  3. 1stopnonprofitshop
    It almost worked. It took the animation away, but some items still take an extra second or so to load...like the 2nd and 3rd testimonial and the "Mission" section in the footer.
  4. nitin
    nitin Guest
    Hope you are doing good...!
    You would be glad to know that we have fixed the issue as per your requirements.
    Now the animations from the sections you mentioned are totally removed.
    Kindly check and acknowledge us for the same.
    Nitin
