Delete functions Ratings and Reviews
Discussion in 'GeoCraft WordPress Theme' started by chndr, Apr 8, 2013.
  1. chndr
    chndr Member
    Hi Team,
    For my concept it's not proffesional rate a listing and add reviews. How can I delete or disable this function?
    Thank you
  2. chndr
    chndr Member
    Hello again,
    I have already disable almost every ratin stars and review. But the last one I cannot find. The widget recently post still shows the stars.
    Where can I find these? Or is there a code to turn this all off at once.
    Thank you
  3. Gourav
    Paste this code in Custom CSS
    .sidebar .review_thumb ul.r_rating {
  4. chndr
    chndr Member
    Hi Gourav, thank you.
    Is it also possible to turn of review and rating with one code for the whole site?
    I have deleted some codes from the templates, but it is better with a code in style sheet.
  5. chndr
    chndr Member
    Oow, I see that your code is not perfect. If you look at the picture there is no space under the listings..
  6. chndr
    chndr Member
    Nevermind, this issue is solved. I used this code:
    .sidebar .review_thumb .r_element {
        padding-bottom:25px;
        margin-bottom:10px;
    But maybe one code for disable this all over the theme would be perfect of course. Now I have to change the code of the templates after each update.
    But thanks your service is great here.
