Hi i Just purchased your theme Security system wordpress theme Eagle eye. After installing the theme i followed your instructions and installed the plugin ad then imported the demo, and the slider has not imported and the pictures have not either. Thins are not working as they should be. Can someone look into this please. http://security.snobmonkey.co.uk/ Thank you
Hi, Greeting from InkThemes, Will you please allow us to check your website dashboard for once? Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will do the needful and resolve the issue for you. Regards, Akbar InkThemes.com
Thank you for importing the demo. I have been playing with the theme and it seems to be confusing and limited to what can be done to the theme. On certain parts, it tells you to refer to the documentation, but the documentation does not exist. Have you got documentation that I can access this theme?
Hi, Greeting from InkThemes, You are WelCome! I would like to inform you that the theme is not limited, there are many things you can perform on the theme. Here is the documentation of the theme kindly go through it: https://www.inkthemes.com/doc/startpoint-wordpress-theme-documentation/ This will surely help you in customizing the theme. And if you face any problem or need help then just let us know, we will surely help you out. Regards, Akbar InkThemes.com
