Deprecated Function mcrypt is throwing errors
Discussion in 'GeoCraft WordPress Theme' started by vsbiz, Jan 9, 2020.
  1. vsbiz
    vsbiz New Member
    Cleveland Ohio
    New install of GeoCraft V2.0.9 is using a deprecated function and the result is the following errors related to specific areas within theme.
    Error occurs with php7.2.x versions and all versions prior to 7.2 are deprecated and not suggested for use.
    Right now I have active site and new test site, both of which throw same error.
    The only resolution seems to be to replace mcrypt function calls with something suitable for php7.2.x
    Abdul Rahman made good suggestion here for replacement
    https://stackoverflow.com/questions...ted-what-is-the-alternative/58486478#58486478
    but unfortunately I cannot do that.....so
    Could you please provide suggestion for workaround or update GeoCraft Version 2.0.9 to handle new function?
    ======copy of my errors thrown while using wp in debug mode======
    Member Dashboard Access
    Fatal error: Uncaught Error: Call to undefined function mcrypt_get_iv_size() in /home/**removed**/public_html/ol/wp-content/themes/geocrafttheme-v2/library/class-encryption.php:30 Stack trace: #0 /home/**removed**/public_html/ol/wp-content/themes/geocrafttheme-v2/library/dashboard/templates/listings.php(28): GC_Encryption->encode('a:4:{s:6:"actio...') #1 /home/**removed**/public_html/ol/wp-content/themes/geocrafttheme-v2/library/dashboard/class-dashboard.php(298): include('/home/**removed**...') #2 /home/**removed**/public_html/ol/wp-content/themes/geocrafttheme-v2/library/dashboard/class-dashboard.php(130): GC_dashboard->user_listing(41) #3 /home/**removed**/public_html/ol/wp-includes/class-wp-hook.php(288): GC_dashboard->view('') #4 /home/**removed**/public_html/ol/wp-includes/class-wp-hook.php(312): WP_Hook->apply_filters('', Array) #5 /home/**removed**/public_html/ol/wp-includes/plugin.php(478): WP_Hook->do_action(Array) #6 /home/**removed**/public_html/ol/wp-content/themes/geocrafttheme-v2/template_dashboard.php(19): d in /home/**removed**/public_html/ol/wp-content/themes/geocrafttheme-v2/library/class-encryption.php on line 30
    Member Add Listing Access
    Warning: sizeof(): Parameter must be an array or an object that implements Countable in /home/**removed**/public_html/ol/wp-content/themes/geocrafttheme-v2/library/geocraft-functions.php on line 43
    ======copy of my errors thrown while using wp in debug mode end===
    and as per evanedgar in previous post on forum
    https://www.inkthemes.com/community...an-object-that-implements-countable-in.23637/
    Getting the following error:
    Warning: sizeof(): Parameter must be an array or an object that implements Countable in /......./wp-content/themes/geocrafttheme-v2/library/geocraft-functions.php on line 43
  2. shemaela21
    shemaela21 Guest Staff Member
    Warm Wishes From InkThemes,
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    C-Panel Website URL: -
    C-Panel Username: -
    C-Panel Password: -
    We will let you know the needful.
    Shemaela
  3. vsbiz
    vsbiz New Member
    Cleveland Ohio
    Done...Thanks
  4. shemaela21
    Thanks for Emailing!
    We have successfully received your support request on our Email.
    Our team member will contact you soon regarding the query you have.
    Kindly be patient until we get back to you.
    Shemaela
