Description issue
Discussion in 'Appointway WordPress Theme' started by pauljw, Jul 4, 2017.
  1. pauljw
    pauljw Member
    Can you look at the attached screen shots.
    I can seem to find how to change the description from what is says in the page source. to what i want, which is in the SEO part.
    it won't change on the serp snipt and is stopping me getting any higher. Web site: https://www.merlinclean.co.uk
    Thank you.
  2. akbar92
    It seems like you are using Yoast SEO plugin with our theme, so you have to change Meta Description from the Yoast SEO plugin setting.
    Hope this helps...!
    If the problem persists, do let me know.
    Akbar
  3. pauljw
    pauljw Member
    Hi, I have looked, but i can't find where to change this description in Yoast. There is a description box in the SEO part of the yoast plug in. I have changed this, see screen shot in my previous post.
  4. akbar92
    There must be a cache issue on your browser. For once, try refreshing the page by pressing Ctrl+F5 and then clearing your web browser's cache.
    Akbar
  5. pauljw
    pauljw Member
    Hi, Thank you, that works.
  6. akbar92
    You are most Welcome!
    Always feel free to ask your queries at our support forum:
    http://inkthemes.com/community/
    We would be glad to assist you...
    Have a nice day!
    Akbar
