Hello, 1. I submit a test post from the frontend but only the category and date listed is showing also no map is showing 2. I uploaded two images but only one is showing Can anyone help with this? Thanks
Hello, There is an filter in the custom fields through which you can exclude your desired fields to show at the free listing. 1, 2) Please go to the Dashboard > Geocraft settings > Custom fields and edit "address field". At the bottom there is an option to enable field for free listing. Follow same process for description, image and other fields. Just check it. And save that field. Check image for reference. Thanks & Regards Nitesh Raghuwanshi
