Hello, I just moved to a different server, etc.. and I'm experiencing exactely the same problems as last year when I set up colorway on my site. Two main problems: the menu, I can't customize - nothing shows to choose from in "menu". My biggest problem: the permalinks - I can only use the default ones. If I choose customized permalinks, then for the blog it gives me a 404 message (once swiching to view page) and Leadpages which I would like to use for my squeeze page doesn't work. It gives me that message: "LeadPages plugin needs permalinks enabled!" Thanks for your help, Jessica
Hello !! It would be nice to get a reply!!!!! Somebody who posted a question after got an answer. I never got one. And this is a major problem. A recurrent one. Last year, one of your techies had to take care of it by logginng into my dashborad to fix it, so I'm certain this will be again the case, since it's exactely the same bug in the theme..
Hello, This is not the theme issue, you are switching the server due to which the permalink issue occuring. So contact with your service provider regarding this issue, they will help you. However, you can provide us the following information listed below. Thread Link: http://www.inkthemes.com/community/threads/different-problems-menu-permalinks.9746/ Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] We will check and try to resolve your issue if possible.
Thank you for your reply. It is not a server issue because I have two sites with the same provider and the other site is not doing that. Sending all the infos to get on my dashboard to the support email.
