difficulty with theme color / top header
Discussion in 'Foogo Pro WordPress Theme' started by faceless4all, Jun 15, 2015.
  1. faceless4all
    faceless4all Member
    Hi, the theme is behaving strange, there is a picture in the top header that came with theme, sometimes it appears other time it does not. I want to remove this.
    Also, the theme colors are not accurate to the color names.
    As a test,
    I used code for opacity, to lighten the color of lime green #header .header-overlay {
    opacity: 0.2;} , and when I did this the picture I mention above displays.
  2. Sobhagya
    Sobhagya Guest
    Could you please provide your site URL along with some edited screenshots so that I can assist you accordingly. If you are unable to create screenshots then you can use www.screenpresso.com
    that will help you to create screenshots.
    Let me know.
  3. faceless4all
    faceless4all Member
    A screen shot isn't going to show you anything, it's the behavior of the theme, even now it changed colors by itself. ! It is making me crazy! haha
  4. faceless4all
    faceless4all Member
    You can close this, I have mentioned the error in my most recent post, titled 'Problems with Theme'
