Hi, I`m having some trouble with your new product. I have imported some 30 products and only the first (home) page shows 10 products. The other pages give a not found message. Do you have a workaround for that issue ? Also i hope you update the plugin/theme so that it doesn`t import duplicate products as it is doing now. Thanks, Charles..
Hello, Greetings from InkThemes! Could you please provide us 'URL' of your site along with some edited screenshot of the concerned area so that we can better assist you? If you are unable to create screenshots then you can use www.screenpresso.com that will help you to create screenshots. Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
I have exactly the same problem products only show on the first page and a 'cannot be found ' message appears when I click on the link to pages two and three. I have no idea how to solve this so without a solution the theme is of no use to me. http://alldigitaldownloads.com
Hi, Greeting from InkThemes, We need WordPress admin credentials to figure out the issue. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will try to fix your issue. Regards, Akbar InkThemes.com
