Display Categories and Sub-categories
Discussion in 'ClassiCraft WordPress Theme' started by benchie2k3, Mar 17, 2016.
  1. benchie2k3
    benchie2k3 New Member
    Dear sir,
    How can I display the categories and the sub-categories all at the same time once the page loads without having to click on the + sign (to display sub-categories)
    Thank you for your quick repsonse
  3. benchie2k3
    I am have limited access to a PC now.
    You can see what i mean at this link: www.inkthemes.com/wp-themes/classicraft-classified-wordpress-theme/
    Kindly scroll down towards the section titled: FULLY RESPONSIVE THEME
    The screenshot there shows the arrangement of the categories all displayed at once on an iPad tablet.
    Here you may see Jobs, Education, For Sale and Computer categories in red color.
    #categories .catcol ul ul {
        display: block !important;
  5. benchie2k3
    Thank you Priya.
    It does very well.
  6. benchie2k3
    Please look at this image below:
    I want all the categories to be on one line. From the image I attached, I want Electronics to be on the same line with other categories. I had adjusted the $cols argument ( to have more than two columns) in the function that displays the categories.
    Thank you for your help.
  7. classicraft2016
    classicraft2016 Guest
    Hello
    1. there is no homepage slider showing at all only the category slider, how do i get this to show please ?
    2. when posting an ad the google maps feature is not showing. It will only show if i use the advance location field which i don't mind but how do i edit the fields in this as i do not want all countries and states showing as an option as i am building a locally based website in the UK. I would also want the state option showing on the published ad not just the country.
    3. in the search bar it says zip code as an option, i am in the UK and this should be post code.
    4. is it possible to change the colour of the post free ads button to match my site as this is starting to look out of place.
    Please help with the issues above. I wish to use your themes but only if i can get it to work correctly.
  8. nitin
    nitin Guest
    I would be assisting you on your issues one-by-one :-
    1. To add the homepage slider to your theme, you can use the following plugin:-
    https://wordpress.org/plugins/ml-slider/
    2. Regarding the google map feature that is not being displayed when the option is not selected from the advance location field, I would like to let you know that we have forwarded this to the concerned department and will try to implement this in the future versions of the theme.
    Also, regarding the state option, I would like to inform you that full address of the listing appears on the listing details page. It displays the Street Address, City, ZIP/Postal Code, State & Country. For your reference please have a look at the screenshot below.
    3. To change the text 'zip code' to 'post code', Please follow the screenshot given below.
    4. You would be glad to know that YES, you can change the color of the 'POST BUTTON'. Just let me know the color code, so that I could assist you accordingly.
    Nitin
  9. benchie2k3
    I have been waiting for your response on this issue for a week now. THIS POST WAS POSTED ABOVE IN THIS THREAD WITH NO REPLY..
  10. priya
    Please provide us 'URL' of your site so that we can better assist you?
  11. benchie2k3
    Dear Support,
    I want my menu this way as shown in this screenshot...
    Also, i have changed the default location of the categories to the spot below the logo
  12. benchie2k3
    Can someone reply on this thread. This is since Wednesday...
  13. priya
    Done the changes in your site as per your requirement..
    Kindly check your site..
  14. benchie2k3
    Thank you.
    I see it done. But please, by doing so, you have shortened the width of the search bar below the menu.
    The search bar is usually as wide as the width of the screen
  15. benchie2k3
    Thank you.
    The search bar is usually as wide as the whole screen
  16. priya
    Done the changes...
