Display differences in different browsers
Discussion in 'Compass WordPress Theme' started by chrisw, Nov 3, 2017.
  1. chrisw
    chrisw New Member
    Before I investigate further is there a known issue where some browsers (or settings) show the primary widget area at the bottom of the page instead of right column? I am seeing this with some IE browsers but have not come down to what they have in common.
  2. chrisw
    chrisw New Member
    I can duplicate the problem on IE placed in compatibility mode. Although, some PCs that access this page see problem with compatibility mode on and some with it off. ?????
    I am also seeing that the menu is not working. There is no dropdown on hover. The colors on the side are gone.
    ALL WORKING GOOD IN CHROME
    SAME PAGE IN IE
  3. chrisw
    chrisw New Member
    I have deleted and re installed the compass pro theme. Deleted Additional CSS. Same exact issue. Deleted cache on browsers. I have even installed the theme on another internal site and am getting exactly the same results. Is there another theme similiar to this that I can use? I have already put a good amount of time into trying to get this to work for all visitors. Thanks
  4. akbar92
    I can understand you but our all themes are Cross-Browser compatible, You can see our theme demo is running smoothly in IE, please have a look at these screenshots (https://screenpresso.com/=rvkJd and https://screenpresso.com/=j7Vsf).
    Here is the link to the theme demo: https://inkthemes.com/wptheme/compass-pets/
    You are requested to share your website URL and admin credentials at [email protected] along with the thread link so that we could resolve your issue.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    Akbar
  5. chrisw
    chrisw New Member
    Thanks for our reply. I got it to work adding the following after <head> in the header.php file
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    All my IE browsers are working now.
  6. akbar92
    Sounds pleasant...
