Displaying Popup on Posts within CATEGORY
Discussion in 'Popup Ninja WordPress Plugin' started by vickistep, Jan 31, 2013.
  1. vickistep
    vickistep New Member
    Hello. I purchased your popup plugin because it said you could select which posts and pages to activate the popup on. However, I need to activate the popup on Single Blog Posts, but only within a certain blog category. Please consider adding this feature to your next update! In the meantime - if there a manual fix somewhere for this in the PHP or JS perhaps? Thanks.
    You can select page to activate the popup. but it is not possible to activate popup on particular category.
