<div> does not work
Discussion in 'BlogsTrend WordPress Theme' started by interaction, Mar 23, 2015.
  1. interaction
    interaction Member
    In a page with full width http://www.holidaybreaks.nl/aanbiedingen/ I put this code
    <div id="tt-tw-23b0c05a"></div>.
    Unfortunately it doesn't work. It worked in the previous theme and on other Wordpress website. Any idea how to solve this?
    Thanks!
    Yvonne
  2. sameerwalkar
    sameerwalkar Guest
    Hi Yvonne,
    Could you please let me know what exactly do wish to do with some edited screen shots, that will help me to guide you accordingly.
    Sameer
  3. interaction
    interaction Member
    Hi Sameer,
    It should like this http://www.wellnesselect.nl/test/ but you see an empty page. And I did nothing special, the same as for HolidayBreaks.nl
    Thanks!
    Yvon
  4. sameerwalkar
    sameerwalkar Guest
    I got your concern. Could you please provide us some edited screenshots where you have tried to put this div to make it reflect was is it a post or a page?. As I have checked at my end by putting html code in post "text" section.
    Sameer
  5. interaction
    interaction Member
    Hi Sameer,
    I put it also on the text part of the page but if you look at the page you see nothing ... http://www.holidaybreaks.nl/aanbiedingen/
    Don't understand as it used to work with another theme and also at another website.
    Thanks!
    Yvonne
  6. sameerwalkar
    sameerwalkar Guest
    Kindly check the video provide in below link. I have tried to put your <div> that you were trying to put in page its working.
    http://screenpresso.com/=O2Fjf
    Sameer
  7. interaction
    interaction Member
    Sameer,
    that's the same I do and then get ... it does not show the travel widget as in this page
    it also used to work on holidaybreaks.nl but in the previous theme.
    Yvonne
  8. sameerwalkar
    sameerwalkar Guest
    If its not reflecting then kindly try and install a fresh copy of your theme from members area. Also its recommended that before installing create a backup.
    To create a backup first by install and activate WP EDITOR plugin.
    Then go to Dashboard->Appearance->Theme Editor
    click download theme button to download your current theme
    Now go to Dashboard->Tools where you will find Export website contents.
    just do like this and in this way your site's backup would be ready.
    Now you can re install theme as i have told you.
    Sameer
  9. interaction
    interaction Member
    Sameer,
    I did everyting up to reinstall theme ... I downloaded the theme just 2 weeks ago, has it changed since then?
    I don't want to end up doing things again. I will install the theme on another website shortly; what should I do so the <div> travel widget works there?
    Yvonne
  10. sameerwalkar
    sameerwalkar Guest
    Please provide the following information listed below I will take a look what exactly went wrong and also kindly send us the page name and div content you want to insert .
    This Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    Send this information to our email at [email protected]
    Sameer
  11. sameerwalkar
    sameerwalkar Guest
    I checked your page that you have provided its working fine. it seems that the iframe code that you were trying to insert in the <div> is missing something as if put some other contents or iframe code the page works fine. If you wish you can provide us your <div> code we can try at out end. let me know.
    Sameer
