Dividers to Separate Widgets in Left Sidebar
Discussion in 'ColorWay WordPress Theme' started by 1stopnonprofitshop, Apr 22, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    Is there any way to have any kind of dividers to separate the widgets in the left sidebar so they don't all blend?
    .feature_blog_content .sidebar.home {
        border-right: 1px solid black;
  3. 1stopnonprofitshop
    It didn't do anything.
  5. 1stopnonprofitshop
    theme1.1stopnonprofitshop.com
  6. priya
    I have checked your site and the left sidebar border is already over there..
    Please have a look over below screenshot..
  7. 1stopnonprofitshop
    I'm trying to add them horizontally so the widgets don't blend together (drawing lines in screenshot where I want the separation).
  8. priya
    Sorry, but could you please resend your screenshot as I am unable to open your attachment...
  9. 1stopnonprofitshop
    Here is another screen shot. Just want horizontal lines (as shown in red) to separate the different widgets. Or a border around the whole thing would be fine too...1 border per widget.
  10. priya
    Use below code for that..
    .sidebar-left div {
        border-bottom: 1px solid black;
    Hope this will work as per your requirement..
  11. 1stopnonprofitshop
    Using that code added way too many lines...see screen shot attached or website at theme1.1stopnonprofitshop.com. I just want one line between each widget to separate them.
  12. priya
    Use below code..
    .sidebar-left h2 {
  13. 1stopnonprofitshop
    Almost right...except lines are still not where I want them. You can see where the lines were put when I added the code...but in red, I marked where I want the lines.
  14. priya
    Use below code..
    .ecwd_calendar.ecwd-widget-mini, .sidebar-left ul, form#form-wysija-2 {
    Hope this will work as per your expectation.
  15. 1stopnonprofitshop
    That's exactly what I want..except it added a weird little line to the calendar. (Image attached). If that can't be fixed, I'll deal with it. Any way I can get a little gap between the end of the widget and the horizontal line? Also, how do I do the coding when I add more widgets, so it continues to add the horizontal line?
  16. priya
    It seems that you have missed out to attach the screenshot along with your post.
    For you second issue, i.e. to add a little gap between the end of the widget and the horizontal line.
    For this, code is given below..
    ul.smbt-social-icons {
        padding-bottom: 15px;
    After adding other widgets, it might be possible that the horizontal line will show over there...If not, let me know I will provide you code for that as well..
  17. 1stopnonprofitshop
    The padding worked, but only underneath the social media icon widget...the others stayed the same. How do I add the padding underneath all the widgets?
  18. priya
    Use below code..
        padding-bottom: 10px;
    .sidebar-left div {
        padding-bottom: 5px;
        margin-bottom: 0;
    Hope you will get it resolve..
