Documentation for Colorway
Discussion in 'ColorWay WordPress Theme' started by Sandra, Aug 23, 2015.
  1. Sandra
    Sandra Member
    I can't find the documentation for Colorway in my members area - could you please provide for the latest version?
    And, I've just uploaded the latest version 3.6.0 (incidentally, it would be good if you could email when there is an update available) but , some "demo information" has been loaded up with it and I now have 4 widgets on the bottom of the page. These seem to be bespoke? But I can't find how to personalise them anywhere - e.g. How do you select the images for "Our gallery" in Widget 3.
    Hopefully the documentation will explain this?
    Thank you
  2. nitin
    nitin Guest
    Though we have sent the updated documentation mail to our every member, we are sorry if you didn't get that.
    No issue, we have updated the documentation for Colorway consisting of information about every updated feature in the latest version. You can access it from your members area.
    Now, regarding the personalisation of the widget area at the bottom of the page (as you queried), I would like to inform you that the section you see is a Dummy area that we have created. If you need to personalise it, please use the NextGEN plugin to customise the gallery.
    Nitin
  3. Sandra
    Sandra Member
    Thank you - I now have the updated documentation.
    I am not familiar with the NextGen Gallery - does this give a widget that you can then select images and links with in the circular form that is showing in your demo area? Any guidance would be much appreciated as it looks very nice if I can just customise it for my site!
    Sandra
  4. nitin
    nitin Guest
  5. Sandra
    Sandra Member
    Thank you Nitin - that is helpful.
    Could I please ask what settings were made for the nextgen-gallery plugin to produce the widget in the footer of Colorway Pro ( see below) ?
    Thank you,
    Sandra
  6. nitin
    nitin Guest
    Hi Sandra,
    Thanks for reporting.
    I would like to let you know, that the gallery section in the theme did not employ Nextgen-plugin.
    It was just a dummy created to let the users know that they could create an image gallery there. Please refer to the previous link provided for any information.
    Regards!
    Nitin
  7. nahdecom
    nahdecom New Member
    How can I remove the complete section of this footer?
  8. priya
    Hello Sandra,
    You can easily remove this section, you just have to paste the CSS code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    .footer-container {
        display: none !important;
    Inkthemes.com
  9. aseeit
    aseeit New Member
    How do you make the gallery thumbnails circular like your example?
    I've installed NextGen but can only make the thumbnails square or rectangular.
    Thanks in advance
    Nico
  10. priya
    Inkthemes.com
  11. aseeit
    aseeit New Member
  12. priya
    Hello Nico,
    .ngg-widget img {
      height: 95px !important;
          border-radius: 50%;
      width: 99px !important;
    Note: Be sure border-radius should be 50% and change the height and width as per your requirement.
    Inkthemes.com
  13. aseeit
    aseeit New Member
    You're the best.... It worked perfectly.
    Thanks for all your help and fast support.
