I have been playing with the theme and it seems to be confusing and limited to what can be done to the theme. On certain parts, it tells you to refer to the documentation, but the documentation does not exist. Have you got documentation that I can access this theme? it is the Eagle Eye security theme. http://security.snobmonkey.co.uk
Hi, Greeting from InkThemes, You are WelCome! I would like to inform you that the theme is not limited, there are many things you can perform on the theme. Here is the documentation of the theme kindly go through it: https://www.inkthemes.com/doc/startpoint-wordpress-theme-documentation/ This will surely help you in customizing the theme. And if you face any problem or need help then just let us know, we will surely help you out. Regards, Akbar InkThemes.com
