Does not display slider
Discussion in 'Squirrel WordPress Theme' started by karibou, Sep 7, 2014.
  1. karibou
    karibou New Member
    Hi, I installed squirrel 2 weeks ago and it was displaying the slider was showing images and working. I have not done anything to the website since then.
    Yesterday I logged in to start adding to the website and updated to the new version of WP, now it does not display the slider.
    I set the speed at 2500 and have 3 images but you can not see a slider on the wesbsite now.
    See http://www.thebrackenfernmanor.com/
    My client is upset. Please Help!
    Thank you
  2. karibou
    karibou New Member
    Also…I deleted the images when I saw the slider was gone.
    Then I added the images again but still no slider.
    Then I removed the Squirrel theme and downloaded a fresh copy from INK themes again. Uploaded it to the website and there is still no slider.
  3. Yogesh
    Yogesh Guest
    Download a fresh copy of latest theme and reinstall it, your problem will fix.
    If it will not fix then let me know.
    Yogesh Bhade
  4. karibou
    karibou New Member
    Hi Yogesh - if you will read my question again you will see that I did download a fresh copy and installed it.
    You will also see that I included the URL : http://www.thebrackenfernmanor.com/
    WordPress has updated. Maybe it is a WP update problem
    Thank you
    This is what I wrote above:
    Thank you
  5. Yogesh
    Yogesh Guest
