Does Slice (and other InkThemes) support multi-language?
Discussion in 'Slice WordPress Theme' started by gmhosting, Mar 3, 2014.
  1. gmhosting
    gmhosting New Member
    Hello!
    I use Slice for a client site, and I need 2 languages. Using the *superb* Polylang plugin I'm able to translate menus and pages, but... how to translate home page? The translation strings are not available...
    Any suggestion?
    many thanks.
    If you want to translate the theme in multiple language then you can achieve this through
    qTranslate plugin,
    See the link for reference
    http://www.inkthemes.com/how-to-translate-your-wordpress-website-using-qtranslate-plugin/01/
    or
    Instead of translating each text manually you can use "Google language translator" plugin.
    It will translate your whole text very easily.
    Download it from the link given below.
    http://wordpress.org/plugins/google-language-translator/installation/
    Also check the link for reference
    http://www.inkthemes.com/make-multi-language-website-by-using-google-language-translator-plugin/08/
    Gourav Shrivastava
