I set a static page as homepage and for the blog another page in reading setting. In the blog page, altough I set like template "blog" at the end of the page, don't appear the menu navigation to view old article. The code is present in the template file. url: http://www.tuttoamerica.it/blog-tuttoamerica/ Thanks.
Hi ikarl! When you select blog page as static page the WordPress not allows you to use their query function on static page, which is used to generate pagination links, so it is recommended that you must have to select your blog page as your post page rather than static front page on reading settings option. Thanks, Praveen
Hi, thanks for your response, unfortunately this don't solve my problem. I use other inkthemes theme (elite) and for that theme it's possible set in reading section front page and blog page, and it shows the pagination, so I think that the problem is in woodpecker theme.
If I put navigation code in loop file, the navigation menu appear, obviously at the end of every article.
Hello, ikarl! I agreed with your statement that you have mentioned in your earlier reply about setting in "Elite Theme". It shows pagination after selecting front page as a blog page under the reading section. But when you will click on "Pagination" to go to next post, it will redirect you to the same post page and all the blog posts will remain same in that page. So, I will suggest you to check whether pagination works at your end or not. If it works, then please provide us a video link of your testing. Thanks, Praveen
