Drop down menu color
Discussion in 'Real Photography WordPress Theme' started by appleguy, Aug 21, 2015.
  1. appleguy
    appleguy Guest
    How do I change the drop down menu color? Thanks.
  2. nitin
    nitin Guest
    #menu .ddsmoothmenu li ul {
            background: blue;
    Note:- Here I have custom set the color to 'Blue'. Please change the color accordingly.
    Nitin
  3. appleguy
    appleguy Guest
    Thanks perfect, how can I make the menu text white?
  4. nitin
    nitin Guest
    That's a very easy task to be accomplished.
    ul.sub-menu li a{
    color: red !important;
    Note:- Please change the color accordingly.
    Hope it will resolve your issue.
    Nitin
