Drop down menu hover color
Discussion in 'Appointway WordPress Theme' started by pupwild, Apr 30, 2013.
  1. pupwild
    pupwild Member
    How could i change the drop down menu hover color?
  2. Harmeet
    Harmeet Support Staff
    Put the following code in your custom css
    Appearance -> theme options -> styling options -> custom css
    #menu .ddsmoothmenu li li a:hover {
    background: red;
    #menu .ddsmoothmenu li li:hover {
    background: red;
    You can change the color according to your requirement
    This will solve your problem.
    Thanks.
  3. pupwild
    pupwild Member
    this did not work too well, it is changing the tab color in the drop down, i want the words to change to a different color, not the tab when you highlight it.
  4. Piyush
    Paste the following code in your custom css
    color:red;
    Inplace of 'red' you can put your color or color code.
