Duplicate title issues.
Discussion in 'Appointway WordPress Theme' started by pauljw, Aug 11, 2013.
Does anybody else have problems with duplicate titles when using the Yoast SEO plugin?
Poll closed Sep 1, 2013.
  1. Yes, but I fixed it by doing this ....
    0 vote(s)
    0.0%
  2. No, it works fine.
    0 vote(s)
    0.0%
  3. Yes I have issues but I cant fix them.
    0 vote(s)
    0.0%
  4. Yes I have issues but I can't fix them, but I am staying with the Yoast plugin because of the result
    0 vote(s)
    0.0%
  1. pauljw
    pauljw Member
    I am finding that my titles are being duplicated.
    This is looking very messy and cramped on the search engine results, and I am sure it is not doing me any good from the point of seo. (please see attachment).
    I am using the Yoast seo plugin.
    There are so many different oppinions and fixes written about this issue on the forums, that I dare not try anything.
    I am wondering , as the writers of this theme, if you can offer any advice to stop this. Bearing in mind that I am not able to do complicated code things.
    Many thanks,
    Paul.
  3. pauljw
    pauljw Member
    Hi Gourav,
    Thanks for your reply.
    I went to replace that code your posted.
    The code was already set as that. <?php wp_title(''); ?>
    I have checked back to the search engine listings, and they are still the same as the screen shot above.
    I checked the Yoast box to say force rewrite titles a few days ago. That has not made a difference.
    Paul.
  4. Gourav
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    We will check your issue.
  5. pauljw
    pauljw Member
    Hi, Just to say that I think the issues may be solved. I can't find the issue today. Perhaps the force rewrite did the trick.
    Many thanks
    Paul
