These fonts show as images and I can't change it. Looked everything already. www.terapiadapalavra.com.br Can you help me?
Hello, For your information, we are using cufon.js in Dzonia Theme which convert text/headings into an image. So, to apply changes in the text/headings you must have to disable cufon.js. Don't worry! Please follow the screenshot given below. Thanks, Praveen
My menu is different, Praveen! 404 Template (404.php) Archives (archive.php) Attachment Template (attachment.php) Author Template (author.php) Blog Page Page Template (blog.php) Category Template (category.php) Comments (comments.php) Footer (footer.php) front-page.php admin-functions.php admin-interface.php captcha.php dynamic-image.php inkthemes-functions.php latest_post_widget.php shortcodes.php theme-options.php Theme Functions (functions.php) Header (header.php) Main Index Template (index.php) loop.php Page Template (page.php) Search Results (search.php) Search Form (searchform.php) sidebar-footer.php Sidebar (sidebar.php) Single Post (single.php) Tag Template (tag.php) Contact Page Template (template-contact.php) Fullwidth Page Page Template (template-fullwidth.php) Gallery Page Page Template (template-gallery.php) Styles Stylesheet (style.css) Visual Editor Stylesheet (editor-style.css)
Hello, For your information, I am using "WP-Editor" plugin to edit files. You can also download and use it from the link https://wordpress.org/plugins/wp-editor/. After activating this plugin, you will get the same screen as shown in the screenshot. Thanks, Praveen
It worked just fine, Praveen, THANKS! But... the font is identical to the image! (lol) How do I use the family font I've chosen?
Hello, I have checked your website and found you have not disabled the cufon.js yet. Please follow the earlier provided screenshot and disable it. After disabling the cufon, paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: h1, h2, h3, h4, h5, h6{ font-family: Arial !important } Please change the font according to you requirement. If you are unable to disable the cufon.js, then send us your website WordPress login details at [email protected] along with the thread link. We will customize it for you. Thanks, Praveen
Hi Praveen, I updated it, but something really wrong happened (lol), I believe it's my fault. Somehow the sliders disappeared. :S Thank you so much for your patience! Rachel
Hello, Rachel! Let me know if you have fixed the issue. If not, then send us your website WordPress login details at [email protected] along with the thread link. We will have a look at your website and try to resolve the issue. Thanks, Praveen
