Hello, after clicking on the edit ad button at the user dashboard (not the WordPress dashboard), the information of the specific ad is loaded. You are now at the Edit Ad section. However .dashcontent's opacity of 0.3 isn't changed back to 1, TinyMCE and Google Maps aren't loaded. If you reload the page, dashcontent gots its opacity: 1 and everything is fully loaded. It seems, that line 247 in library\dashboard\js\dash-scripts.js is causing the problem. After executing $('.dashcontent').html(response); nothing more seems to be done. Would you please be so kind and have a look? Hope, you can solve the problem. You should got your credentials for the site. Kindly regards
Alright, could solve the issue at myself. I had to add a conditional statement in a custom javascript file.
Hope you are doing good....! I really appreciate your efforts in exploring the things and sharing your knowledge here. It seems that you have resolved your issue by your own. Let me know if you have any doubts regarding the functionality of the theme, so that I can assist you. Thanks & Regards! Nitin InkThemes.com
Hello, I have the same error. In the console of Firefox (42.0). I noted when this error appears the message, " ReferenceError: FillRegion is not defined " after the refreshment everything becomes normal and publishable without error in console. I do not find a solution for this problem, what is the fix for this problem. Otherwise the theme works perfectly. thanks for your help. Best regard.
Hello, Greetings from InkThemes! Sorry for the trouble. We have forwarded this issue to our developers and will notify you ASAP.. Your patience will be appreciated, Thanks & Regards! Priyanka InkThemes.com
Hello, Thank you for your answer. Let us wait for the answer of Development service. Thank you for your help. Best regards.
Hello, Have you news about this problem. Before publishing my web site this problem must be solved. Thank you for your help. Best regards.
Hello, I would like to suggest you to please download latest version of the theme.. I have tested your issue at our end and everything works fine.. Here I am also providing you a video, please have a look: Link: http://screenpresso.com/=BiKmf Hope you will find it helpful Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hello, Thank you for your answer. I made a new clean installation, Wordpress is in version ' 4.3.1-it_IT ' and the latest theme version (Today Downloaded). The problem remains the same but the error in the console of Firefox is different : ' Reference Error: Google is not defined jquery.js:178:8 '. If you reload the page everything becomes normal (opacity to 1) and Ad publishable without error in console. I test the installation with the theme in two differents web server and i have the same problem and the same error in console. Thank you for your help.
Hello, Sorry to learn this.. Could you please send us your dashboard details at [email protected] along with this thread link as well so that we can figure out the issue and able to resolve that? Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
Hello, I am going to redo on web server a clean installation and i shall communicate with you the useful information by email. Thank you for your help.
Hello, Friday 4/12 I sent the informations on the email address "[email protected]" for you to see the problem with the tittle : " For Priyanka : Problem Edit Ad Dashboard". By email Naveen Kolhe responded that the information was received. Waiting for your return. Thank you for your help.
Hello, Thanks for the details.. We will get back to you soon. Your patience will be appreciated, Thanks & Regards! Priyanka InkThemes.com
