Hye sir, May i know the purpose of PSD file you provide for the theme? I would like to edit a layout of header, make it the width longer. I try edit the PSD file, but i do not know where to replace the edited layout image. Attached is my edited layout. Is it possible to edit? Thanks in advance.
Hello normasita, Code: .slider_info { margin-left: -60%; width: 100%; } .flexslider { width: 208%; margin-left: -50%; } .flexslider .slides img { width: 100%; } Thanks, Praveen
Hye Praveen, Thank you for your prompt reply, there are some questions i would like to ask u further: Code: .slider_info { margin-left: -60%; width: 100%; } .flexslider { width: 208%; margin-left: -110%; } .flexslider .slides img { width: 100%; } above codes change the slider image to center, but the image inside the slider are streatch, how can i know the actual size of the box for the slide image? where can i refer? and last question is when i view in mobile phone, the header is not allign, any setting should i do? here is my URL, feel free to visite Code: ciknursingxxxl.com [code] Your respond are highly appreciated. TQ
Hello normasita, 1>To make slider in proper position, please use the code given below in custom css. Code: .flexslider { margin-left: -50%; } 2>Use image of size 1000*300px for the slider. 3>Please explain a little bit more about your issue related to header in mobile view. It will be better if you provide us some edited screenshot of the issue. Thanks, Praveen
