Edit homepage overlay color
Discussion in 'Foogo Pro WordPress Theme' started by hitechpanda, Nov 24, 2015.
  1. hitechpanda
    hitechpanda Member
    I want to remove the overlay color on homepage but keep the overlay color for menu. How do I achieve this?
    I have added the following code and it removes the whole overlay color:
    #header .header-overlay {
    background-color: rgba(255, 255, 255, 0);
    Could you please provide us 'URL' of your site with some edited screenshots so that we can assist you accordingly?
  3. hitechpanda
    hitechpanda Member
    Hi Priya,
    I attached the site name and a screenshot link on txt file. Not sure how to add private section here.
    As I guess from your above words and screenshot, perhaps you want to change the color of your top header section..
    So if I am not wrong with your issue, you just need to paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    .top-header {
        background: brown !important;
