edit package offers
Discussion in 'InkThemes-Support Working Hours' started by lifetalk, Aug 2, 2018.
  1. lifetalk
    lifetalk New Member
    Is there a way to disable certain packages? For instance, I don't want the third option to show up on the page.
    I might later want to enable it again in the future but not right now.
    I'd also like more control in this area... For instance adding a link or button image that points to a page that gives more details.
  2. akbar92
    So that we can deliver you an exact and appropriate solution.
    Akbar
