Edit the links in top header.
Discussion in 'GeoCraft WordPress Theme' started by rdeshazer, Dec 30, 2014.
  1. rdeshazer
    rdeshazer Member
    USA
    I'd like to remove the "Add Listing" link from the top header. I was able to remove the line from the the module function file, however "Add Listing" is still showing up on the main home theme page.
    http://www.squirrlit.com
    Thx
  2. Yogesh
    Yogesh Guest
    (GeoCraft Settings -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    .header_wrapper .header .post_btn {
    It will resolve your issue.
    Yogesh Bhade
  3. rdeshazer
    rdeshazer Member
    USA
    Yogesh,
    The code removed "Add Listing" from the top menu bar, but it also seems to have removed the "Post Header Button" I had labeled. I would like to keep the button, also the divider between the top header and the second header is not aligned on the right side.
    Thx
  4. Yogesh
    Yogesh Guest
    Please provide us screenshot which button do you want to remove and also provide us your live website URL.
    Yogesh Bhade
  5. rdeshazer
    rdeshazer Member
    USA
    1. I was able to remove the line from the module function file: "Add Listing" from the upper right top header. I think a refresh was needed to make sure, so it maybe fine now.
    1. I want to keep the "Business Owner Login" and the "Add Your Business Button", however the divider line between the 1st header and the 2nd header to the right is a bit off. see attachment.
      File size:
      376.9 KB
      11
  6. Yogesh
    Yogesh Guest
    (Geocraft Settings -> Theme Options -> Styling Options -> Custom CSS) of your dashboard.
    .header_wrapper .header {
    background: #bc2b2b;
    Yogesh Bhade
  7. rdeshazer
    rdeshazer Member
    USA
    Fixed.
    Thx
