Enabling Rich Pins Plugins
Discussion in 'Andrina WordPress Theme' started by kbrad613, Feb 20, 2016.
  1. kbrad613
    kbrad613 Member
    I downloaded the NGFB plugin to enable rich pins on my posts, but after installing it I got this message:
    The <head> element in your theme's header templates should include a function / action / filter call for its attributes.
    It tried to fix the problem automatically but it didn't work. How can I change the template to allow this?
    Thank you!
  2. kbrad613
    kbrad613 Member
    Sorry, I forgot to add this.... It says to change the default <head> element to:
    <head <?php do_action( 'add_head_attributes' ); ?>>
    smith likes this.
  3. priya
    Could you please send us link of the plugin so that we can test this at our end and will assist you accordingly..?
  4. kbrad613
    kbrad613 Member
    Thanks Priya, but I worked it out. :)
  5. priya
    Hope doing good.
    I really appreciate your efforts in exploring the things...
    It seems that you have resolved your issue by your own.
    Let me know if have further doubts so that I can assist you.
    smith likes this.
