Erase or move Lead Capture Form, possible?
Discussion in 'Blackriders WordPress Theme' started by trasgu, Dec 14, 2013.
  1. trasgu
    trasgu Member
    Santander, Spain
    ((namaste))
    I'm new to this theme and I was wondering if is possible to delete or move down to the widget area the "Lead Capture Form". In most of our photos the artisans face is located in the right side and this From is just in the way, thou we love the Form's functionality :)
    Shot: http://awesomescreenshot.com/01723bv34c
    Thx tons friends and warms regards from Peru!!
    Jose
    EDIT: just found how to add the Form into the Widget area :)
  2. securepro
    securepro New Member
    Could you share the details of how you moved it? I would like to move it all the way over to the right side. I'm having a similar issue with it blocking an important part of my image.. Thanks!
  3. onmark lee
    onmark lee Member
    Yes, I would like to temporaly disable the lead form ....What to do it?
  4. onmark lee
    onmark lee Member
  5. trasgu
    trasgu Member
    Santander, Spain
    Hi guys, you can disable the Lead Form within the "theme options", easy-peasy :)
