Error in Categories and Listings
Discussion in 'ClassiCraft WordPress Theme' started by marinos13, Jan 26, 2015.
  1. marinos13
    marinos13 Member
    Cyprus
    I installed the theme on http://www.realpro247.com/ but i have the following errors:
    1) Categories on the first page are not working.
    2) Listings page doesn't display anything.
    Please advice.
  2. Pramod
    Pramod Guest
    Hello !
    Post ads on that category's subcategory to work categories on home page.
    Do 4-5 post to check its functionality.
    Pramod
  3. marinos13
    marinos13 Member
    Cyprus
    Ok I will try it.
    Also for any address i add on the system google map navigates me on the us. The address doesnt work properly.
  4. Pramod
    Pramod Guest
    Hello Marinos!
    We have checked map it works according to city entered and country entered by clicking on button "Set address On Map"
    Pramod
  5. marinos13
    marinos13 Member
    Cyprus
    This problem have been solved after adding Non Us field in state.
    I still have the problem in categories.
  6. Pramod
    Pramod Guest
    Hello Marinos!
    Please create some subcategories of categories and then check it.
    Pramod
  7. marinos13
    marinos13 Member
    Cyprus
    I did it and it work on the front interface but the user is unable to select a subcategory for the specific product.
    Please try to add lets say a house for sale. You can only select the main category and not the sub category.
  8. Pramod
    Pramod Guest
    Hello Marinos!
    When you select the main category plus sign and it will open its sub category.
    It is necessary to add subcategories on each category to work them.
    Category click only open the subcategory.
    Pramod
  9. dinocarrozzo
    dinocarrozzo New Member
    I've also a problem with subcategories: all the sub categories al shown when I click the first main category. what's the problem? www.comprovendobaratto.it
  10. Pramod
    Pramod Guest
    Hello !
    This is not any issue when some one create more subcategories under main category and also have too many main categories.
    Then it looks so ugly so always initially the subcategories hidden until people click on main category.
    Pramod
