Error on footer
Discussion in 'Andrina WordPress Theme' started by heartlandhosting, Mar 21, 2013.
  1. heartlandhosting
    heartlandhosting New Member
    Our footer is missing on the Blog template (Category and Archives) page. It is reporting the following error: Catchable fatal error: Object of class WP_Error could not be converted to string in /Users/Shared/Web/jmc301/wp-content/themes/andrinatheme/functions/dynamic-image.php on line 267. Any help would be very appreciated.
    re: http://mcluhan.unk.edu/jmc301/?cat=4
    Please check that you are not using .gif images, If you are using it then, change it and use .png or .jpg format images, This will solve your issue.
