errors need help
Discussion in 'Local Business WordPress Theme' started by ekosmin, Jan 5, 2013.
  1. ekosmin
    ekosmin New Member
    have thousands of these in error log. how can i fix?
    [05-Jan-2013 14:23:07] WordPress database error You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'inkthemes_info' at line 1 for query show tables like inkthemes_info made by require('wp-blog-header.php'), require_once('wp-load.php'), require_once('wp-config.php'), require_once('wp-settings.php'), do_action('init'), call_user_func_array, my_plugin_create_table
    [05-Jan-2013 14:23:07] WordPress database error Duplicate column name 'date' for query ALTER TABLE inkthemes_info ADD COLUMN datedateNOT NULL made by require('wp-blog-header.php'), require_once('wp-load.php'), require_once('wp-config.php'), require_once('wp-settings.php'), do_action('init'), call_user_func_array, my_plugin_create_table, dbDelta
