Errors when Updating - AGAIN
Discussion in 'GeoCraft WordPress Theme' started by kentoliver, May 2, 2013.
  1. kentoliver
    kentoliver Active Member
    Hey guys, Getting really tired of this theme, stuff being broken and no help through support for key issues.
    I am ready to launch my site. However I worked on 1.7.4 of your theme. Thinking everything was working with the payment end.
    Lone behold its not. Buying a broken theme, and then spending lots of time customizing it when you didnt realize it was broken is a big let down.
    I need a link to the download of the newest theme.
    Constant errors when updating your theme.
    " Fatal error: Call to undefined function geocraft_get_option() in /home2/koidevel/public_html/crpc/wp-content/themes/geocrafttheme/admin/install.php on line 208"
    So I need the new theme. Also, I need a list of the functionality changes and where you applied them from 1.7.4 to the new theme.
    Please and thanks.
  2. tobyb
    tobyb Active Member
    World Wide
    Hi Kent, when you login to inkthemes you can go to your account purchases and download the latest version of the them there.
    Hope this helps
    Tob
  3. Nitesh
    Below is the lists of files where we did the changes when we switched from GeoCraft Theme Version 1.7.5 to 1.7.6
    1. front-page.php
    2. taxonomy-listcat.php
    3. listing_submit.php
    4. dashboard_functions.php
    5. listing_metabox.php etc
    Also, I am sending you all 3 versions of the theme 1.7.4, 1.7.5, 1.7.6 on your email so that you can look into them to track the file changed and changes that are done.
    To track the changes, I recommend you to install "Beyond Compare" Tool from http://www.scootersoftware.com/download.php to compare the changes between the entire folder of different theme versions so that you can do that changes in your customized theme easily.
  4. kentoliver
    If only that Beyond compare was for mac ><
    Thanks for the list of pages.
    Can you include a list of page edits from 1.7.4 to 1.7.5 as well? As I am currently on your 1.7.4 theme.
