1) Why is the import and export under Geo Craft Settings and not Business Listings? 2) I exported from one website which had two listings and tried to import them into another with one listing (different listing) but am just getting an "Error uploading" message. 3) The Import button is cut in half on the page.
im trying to import file of csv i need to know what would be the best scraper and also with my csv file should i delete the headlines as everytime i export them out of the scraper im using i have to manually change it to post_auth etc etc but when i upload the files i keep getting upload error
I am trying to upload for geocraft & having the same issue - not working & button is cut in half? Can I manually upload to where?
Update your theme to the latest version 1.6.8. Multiple issues are resolved in this version. You can check changelog at http://www.inkthemes.com/wp-content/updates/changelog.txt.
