Export traffica settings
Discussion in 'Traffica WordPress Theme' started by markman641, Mar 9, 2016.
  1. markman641
    markman641 New Member
    I recently had to do a fresh install of Wordpress on a new server because some file in my current setup was corrupted, and in the process also had to do a fresh install of the premium Traffica theme...
    Is there a way to export the settings to upload to a new install? If not, there should really be an option and would be really easy to do too.
    Let me tell you during the fresh installation of the WordPress, there must be some possibilities that your database would be updated and all the settings data are used to store in the database as you know I guess.
    So during updating of WordPress on new server, there would be strong possibilities to lose your previous settings and I am so sorry to say there is no any way to export your previous data...
    Hope you will understand...
  3. markman641
    I figured it out. I exported the old database and imported it into my new hosting and it worked.
    Theme developer should develop an import/export function.
    Sure... We will discuss with our developer and will let you know..
