Facebook Comment option does not work.
Discussion in 'BlogSpring WordPress Theme.' started by amaconline, Oct 7, 2018.
  1. amaconline
    amaconline Member
    Facebook Comment option does not work. Any suggestions?
  2. akbar92
    So that we can deliver you an exact and appropriate solution.
    Akbar
  3. amaconline
    amaconline Member
  4. akbar92
    Are you using any plugin?
    Akbar
  5. amaconline
    amaconline Member
    No I am not. Also I checked the theme documentation and can not find anything there. The theme comes with social commenting feature but it does not work. Do I need to setup anything else?
  6. akbar92
    Greeting from InkThemes,
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do the needful.
    Akbar
  7. amaconline
    amaconline Member
    Hi Akbar, email sent. Thank you.
  8. akbar92
    We have successfully received your credentials, we will get back to soon as we are done.
    Akbar
  9. amaconline
    amaconline Member
    I am very sorry as I sent you login details for a completely different website than the one I mentioned above. The issue is on www.Biographiesofthesalaf.com but I sent you a completely different website, my bad. Please check your email again.
    Many thanks.
  10. akbar92
    We have successfully received your new credentials, and we have forwarded your issues to the respected department.
    We will get back to soon as we are done.
    Akbar
