Hi, still the FB pluging is showing like coding language. http://www.bongomovies.com/samatta-aibuka-shujaa-tuzo-za-afrika-huko-abuja Hope this can be corrected. thanks Honory Jerome
Hello Honory, Greetings from InkThemes! We have removed the code from your site... So you are kindly suggested to configure the plugin once again and check after that.... Hope it will work for you.. Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
can you put the facebook comment plugin instead? let me know if i should resend the login information.
This plugin is very important as I want to lower the bounce rate and also to increase number page visits
Hello Honory, You would be glad to know that I have added facebook comment plugin in your dashboard.. Kindly check.. Thanks & Regards! Priyanka InkThemes.com
Hi Priyanka, I am very happy to see facebook comment plugin working properly now. However, it appears that there are two FB comments plugins. one appearing immediately after the post but the other one appearing after the Ad Banner. Just have a look at this link- http://www.bongomovies.com/picha-lulu-asifiwa-mitupio/ Can you please look at this so that it can be rectified? Be blessed Honory
Hello Honory, Done..!!! Check your site.. Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hi Priyanka, The FB comment plugin has disappeared from the posts--http://www.bongomovies.com/tiffah-dangote-anawasumbua-wengi-wolper/ thanks Honory
Hello Honory, I have checked your link and would like to inform you that plugin has not disappeared from your post.... Please have a look over the screenshot given below. Kindly chek your site.... Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Priyanka, I dont know why the facebook comment plugin is appearing twice from the post: an example, please see this link : http://www.bongomovies.com/je-unataka-kwenda-kuishi-kufanya-kazi-marekani-nafasi-ni-yako/
We need to check your site, Could you please forward your admin credentials to [email protected]? Our team will check and do the needful. Warm Regards! Naveen Kolhe InkThemes.com
